Command Line Set SF by NAME
Posted: Fri Jun 24, 2022 9:09 pm
Hi
Setting active SF usgin the string would be much better because makes the .bat more readable and mor reusable. Even using the same dataset adressing the SF by index becomes a hassle soon after you start adding SF like when computing geometrical features etc -SET_ACTIVE_SF Intensity or whatever other field. would be epic.
