Sensor TLS data.
Posted: Tue Jul 19, 2022 4:51 pm
by larderArch
Hello, I can't find the way to export all the data [TLS / GBL Sensor] of all the clouds at the same time, is there a way? Basically I would like to obtain an x, y, z file with the scan center locations of each cloud contained in a CloudCompare file. Thank you.
- TLS/GBL POINT SENSOR STATION
- 2-TLSDATA.jpg (529.88 KiB) Viewed 1755 times
- Cloud Compare TLS/GBL DATA
- 1-TLSDATA.jpg (217.04 KiB) Viewed 1755 times
Re: Sensor TLS data.
Posted: Fri Jul 22, 2022 8:59 pm
Hum, sadly there's no way to do it currently... Apart if you hack the code of course (or maybe via Python and CloudCompy?)
