Hi I'm currently working on a project using Riegl rdbx files and I gotta say your software is truly amazing - I can do everything I want from the command line. However, when opening Riegl files (using -O) it always asks me what information I want to use, which requires the press of an "Enter" everytime, which I would like to avoid for automation's sake. I could probably fix this using some code that calls the commandline and presses Enter, but I was wondering if there is some flag I overlooked that would allow me to just load it in with the default settings. "-SILENT" doesn't do it, sadly.
I've attached an image of the popup
Thanks in advance!
Automatically open Riegl files in command line?
- Untitled-1.jpg (69.16 KiB) Viewed 1901 times
Re: Automatically open Riegl files in command line?
Ah, no, that's probably the Riegl plugin that is not designed to work in 'silent' mode. Sadly someone would have to update the code so that it doesn't open the dialog when in command line mode...
