Colourise by EDL shader values?
LeeFluff
Post by LeeFluff »
I have some colourless LiDAR data
obviously the EDL shader dramatically improves usefulness of this data for inspection purposes
Is there a way for me to edit the RGB values / overwrite these with the apparent luminance from the EDL shader ?
Re: Colourise by EDL shader values?
Sadly no...
However, the PCV plugin tries to achieve the same goal, and in a way (= as a scalar field) that allows you to change the dynamics, or to export the false colors to RGB, etc.
See https://www.cloudcompare.org/doc/wiki/i ... s_(plugin)
