CANUPO differences between GUI/Command Line
cmackSIO
Post by cmackSIO »
Test
Re: CANUPO differences between GUI/Command Line
If the parameter is properly read, you should see in the (command line) console:
Confidence threshold set to XX
I wonder if another issue might be with the Global Shift? Can you try with the 'AUTO' option?
cmackSIO
Post by cmackSIO »
test
Hard to tell... What about the Global Shift, is it the same? Or maybe it's just a display thing?
