CloudCompare Versions
Posted: Tue Oct 03, 2023 6:06 pm
by mcaradonna
I have v2.13.3.beta downloaded, and am trying to use the command line mode
I want to use -GLOBAL_SHIFT Auto. But it says the command is not recognized. Basically just trying to automate the automatic global shift that is provided when you open a .las file.
The wiki says that I need v2.3, but I cannot find that version while downloading.
Re: CloudCompare Versions
Posted: Thu Oct 05, 2023 7:52 am
What's your full command? -GLOBAL_SHIFT can only be placed after -O
Posted: Fri Oct 06, 2023 12:31 pm
by mcaradonna
cloudCompareCommand = ['"C:\Program Files\CloudCompare\cloudcompare.exe" -AUTO_SAVE OFF ', ...
    '-C_EXPORT_FMT LAS -O "', inputFile '" ', ...
    '-GLOBAL_SHIFT AUTO "' '" ', ...
    '-SAVE_CLOUDS FILE "', outputFile '"'];
Posted: Tue Oct 10, 2023 3:26 pm
So yes, you have to put '-GLOBAL_SHIFT' right after '-O'.
