CC Crush after using the "creates a 2d deviation map" tool
Posted: Wed Feb 28, 2024 4:09 pm
by Getarq
Everytime I use the "creates a 2d deviation map radial distance"tool, CC crush and i lost the work!
I just have to save everything before and then use the tool, because it'll crush.
Re: CC Crush after using the "creates a 2d deviation map" tool
Posted: Sat Mar 02, 2024 9:52 am
Which version are you using?
If it's not the latest 2.13 version, can you try with this new version?
If it is the latest 2.13 version, can you share your data with us? (save all entities as a BIN file and send it to admin@cloudcompare.org)
Posted: Mon Mar 25, 2024 12:12 am
by Getarq
Sorry Daniel, I didn't saw your answer!
Right now I just installed the 2.13.1, and I was using the 2.13 before.
I'll check with this new version and I'll be back!
Thanks.
Diego.
