Page 1 of 2
bare earth extraction - simplified method
Posted: Fri Oct 25, 2013 9:45 am
by hds_surveyor
Hi Daniel
I was thinking of a simplified method of bare earth extraction that uses the octree structure:
1) define a level of octree subdivision
2) divide the point cloud into columns of octree cells and choose the lowest point of the lowest octree cell of each column
3) create a new point cloud with points selected in step 2
it should be a quick and easy way to remove sparse vegetation, people, cars and vertical or overhanging objects from scans
Alberto
Re: bare earth extraction - simplified method
Posted: Fri Oct 25, 2013 12:01 pm
I think the method already exists: it's in "Tools > Projection > Height grid generation".
This method let's you decide of a regular grid step (~ level of subdivision), an orientation (X, Y or Z) and then projects all points in 2D along this orientation, keeping only one point per grid cell. You can eventually choose which point is kept each time (max, mean or min altitude - the latter one will correspond to your proposition).
I believe some users already use it to extract bare earth from aerial lidar data with it.
Thanks for the suggestion anyway (and tell me if I missed something!).
Posted: Fri Oct 25, 2013 5:51 pm
by hds_surveyor
yes, something like this
Posted: Sat Oct 26, 2013 9:12 pm
by hds_surveyor
the heigh grid generator forces the creation of a regular grid, can you only sample the existing points?
Posted: Sun Oct 27, 2013 9:43 am
Good idea. We should add an option to do this with the Height Grid Generation tool. I'll add this to the TODO list.
Posted: Mon Oct 28, 2013 6:58 pm
by hds_surveyor
thanks Daniel
Posted: Mon Nov 11, 2013 2:05 pm
Ok that's done! It will be available in the next release (and it's already available on the github's trunk for those who compile the project).
Posted: Thu Nov 14, 2013 2:34 pm
by hds_surveyor
thanks again, I'll wait for the next release
Posted: Wed Aug 26, 2015 12:01 pm
by AndrewRoberts
Does the height grid generation tool still exist? I do not see it under tools > projections.
Posted: Wed Aug 26, 2015 12:36 pm
by Dimitri
Yes, it's now called "rasterize" and it is much more evolved than the Height grid generation.
