Hello everybody!
I'm Andre, I'm a master's student in my final year and I'm working on my final project, my project consists of collecting 3D images with a laser in different positions and then we have to reconstruct the images.
For example:
We scan a palm in different positions and then have the task of recreating a hand, which would be joining all the dots.
I tried several software until I found cloudcompare. And I wanted help on how I can do this with cloudcompare.
I have no experience with this type of subject, any help would be welcome.
Laser Scanning and 3D Reconstruction.
Re: Laser Scanning and 3D Reconstruction.
Do you mean that you want to register different scans with a small overlap? If yes, then you should look at the ICP tool (https://www.cloudcompare.org/doc/wiki/index.php/ICP). Pay attention to the 'overlap' parameter.
Else, you'll have to share some pictures to help us understand.
Andresilva0409
Good morning Daniel, thank you in advance for your response.
Daniel, I'm going to share the images I got from a test I did, they have a front, side and back view and what I wanted was to learn how to fill in the back, instead of it being the way it is.
- Posterior.png (5.4 KiB) Viewed 5839 times
- Frontal.png (6.1 KiB) Viewed 5839 times
- From The sides.png (6.27 KiB) Viewed 5839 times
Well, it's hard to see (don't hesitate to activate the EDL shader ;), but assuming you have some overlapping surfaces, you can indeed use the Edit > Translate/Rotate tool to roughly align the scans, and then use the ICP tool (see https://www.cloudcompare.org/doc/wiki/i ... gistration)
