use potree viewer inside cloudcpmpare
nikoue
Post by nikoue »
CloudCompare is an excellent software for working with point clouds. However, from my perspective, the only drawback is that the viewer tends to be slow when handling large point clouds.
I wonder if it’s possible to replace the current viewer with the Potree viewer, which is significantly faster. I am not a programmer, so I’m unsure if this can be done, but it would be fantastic to combine the functionalities of CloudCompare with the speed of the desktop version of Potree.
Best regards.
Re: use potree viewer inside cloudcpmpare
Well, that would be neat indeed. But there's a technological issue first, and then potree doesn't have all the capabilities CC's editor has ;)
