Depth slicing
GBJ
Depth slicing
Post by GBJ »
New user of CloudCompare. If I have a 3D volume, is there a way to Slice through it and generate depth slices? For example can I gradually make a layer of Z values invisible, one after the other and gradually slice down through the volume? This is common in other 3D software but I can’t figure out how to do it in CloudCompare. A description or a link to a tutorial would be appreciated. Thanks!
Re: Depth slicing
Yes, you can use the 'Repeat' mode of the 'Cross Section' tool.
See the wiki page: https://www.cloudcompare.org/doc/wiki/i ... r_contours
