Global Shift Settings for Guitar Scan Sizes
Posted: Wed Jan 21, 2026 4:16 am
by Guitar Quackery
I just discovered the Global Shift Settings and read through the description in this box.
Screenshot 2026-01-20 at 11.13.38 PM.png (105.72 KiB) Viewed 24473 times
It is my understanding that Cloud Compare is used a lot for large clouds, such as landscapes.
Since I will only be using it for 3D scans of guitars, what would the the ideal Global Shift settings for my size range?
Thank you very much.
Re: Global Shift Settings for Guitar Scan Sizes
Posted: Wed Jan 21, 2026 8:20 am
If it's mm scans, with coordinates not too far from zero, then you can probably ignore the Global Shift and keep the coordinates as they are!
Posted: Wed Jan 21, 2026 3:01 pm
by Guitar Quackery
Thank you.
