[FIXED] Wrongly reading las file after adding a new dim
I used laspy to add a new dimension to the original las file. The new file works OK in QTreader and FurgroViewer but corrupt in cloudcompare.
- new file
- 2.png (36.56 KiB) Viewed 9860 times
- original file
- 1.png (6.78 KiB) Viewed 9860 times
Re: Wrongly reading las format data after adding a new dimen
We use liblas to open LAS files so there may be an issue whit it. Can you send me your file? (cloudcompare [at] danielgm.net)
Hi, thanks for your concern. can I have your email ? later on I will send you the file.daniel wrote:Hi,
The email 'cloudcompare[at]danielgm.net' (just replace the [at] by @ - it's to avoid automatic spam bots ;)
I have send you the files. Please let me know if the problem is solved. Thanksdaniel wrote:The email 'cloudcompare[at]danielgm.net' (just replace the [at] by @ - it's to avoid automatic spam bots ;)
I confirm that the issue was fixed when upgrading LibLAS to version 1.8.
The new beta version is:
(edit: link removed)
Thanks for the feedback.
