qCC_db version 2.13.alpha (Qt) - 31 May 2022
CloudCompare 3D entities
This is the complete list of members for ccCameraSensor, including all inherited members.
| addChild(ccHObject *child, int dependencyFlags=DP_PARENT_OF_OTHER, int insertIndex=-1) | ccHObject | virtual |
| addClipPlanes(const ccClipPlane &plane) | ccDrawableObject | virtual |
| addDependency(ccHObject *otherObject, int flags, bool additive=true) | ccHObject | |
| addPosition(ccGLMatrix &trans, double index) | ccSensor | |
| applyDisplayState(const DisplayState &state) | ccDrawableObject | virtual |
| applyGLTransformation(const ccGLMatrix &trans) override | ccSensor | virtual |
| applyGLTransformation_recursive(const ccGLMatrix *trans=nullptr) | ccHObject | |
| applyViewport(ccGenericGLDisplay *win=nullptr) override | ccCameraSensor | virtual |
| BROWN_DISTORTION enum value | ccCameraSensor | |
| ccCameraSensor() | ccCameraSensor | |
| ccCameraSensor(const ccCameraSensor &sensor) | ccCameraSensor | |
| ccCameraSensor(const IntrinsicParameters &iParams) | ccCameraSensor | |
| ccDrawableObject() | ccDrawableObject | |
| ccDrawableObject(const ccDrawableObject &object) | ccDrawableObject | |
| ccHObject(const QString &name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID) | ccHObject | |
| ccHObject(const ccHObject &object) | ccHObject | |
| ccHObject_recursive_call0(toggleActivation, toggleActivation_recursive) ccHObject_recursive_call0(toggleVisibility (defined in ccHObject) | ccHObject | |
| ccHObject_recursive_call0(toggleColors, toggleColors_recursive) ccHObject_recursive_call0(toggleNormals (defined in ccHObject) | ccHObject | |
| ccHObject_recursive_call0(toggleSF, toggleSF_recursive) ccHObject_recursive_call0(toggleShowName (defined in ccHObject) | ccHObject | |
| ccHObject_recursive_call0(toggleMaterials, toggleMaterials_recursive) inline virtual void transferDisplay(ccGenericGLDisplay *oldDisplay | ccHObject | |
| ccHObject_recursive_call1(setSelected, bool, setSelected_recursive) ccHObject_recursive_call1(setDisplay (defined in ccHObject) | ccHObject | |
| ccHObject_recursive_call1(removeFromDisplay, ccGenericGLDisplay *, removeFromDisplay_recursive) ccHObject_recursive_call0(prepareDisplayForRefresh (defined in ccHObject) | ccHObject | |
| ccHObject_recursive_call1(refreshDisplay, bool, refreshDisplay_recursive) ccHObject_recursive_call0(resetGLTransformationHistory (defined in ccHObject) | ccHObject | |
| ccObject(const QString &name=QString(), unsigned uniqueID=ccUniqueIDGenerator::InvalidUniqueID) | ccObject | |
| ccObject(const ccObject &object) | ccObject | |
| ccSensor(const QString &name) | ccSensor | |
| ccSensor(const ccSensor &sensor) | ccSensor | |
| checkVisibility(const CCVector3 &P) const | ccSensor | inlinevirtual |
| colorsShown() const | ccDrawableObject | inlinevirtual |
| ComputeFovRadFromFocalMm(float focal_mm, float ccdSize_mm) | ccCameraSensor | static |
| ComputeFovRadFromFocalPix(float focal_pix, int imageSize_pix) | ccCameraSensor | static |
| computeFrustumCorners() | ccCameraSensor | protected |
| computeGlobalPlaneCoefficients(float planeCoefficients[6][4], CCVector3 ptsFrustum[8], CCVector3 edges[6], CCVector3 ¢er) | ccCameraSensor | |
| computeOrthoRectificationParams(const ccImage *image, CCCoreLib::GenericIndexedCloud *keypoints3D, std::vector< KeyPoint > &keypointsImage, double a[3], double b[3], double c[3]) const | ccCameraSensor | |
| computeProjectionMatrix() | ccCameraSensor | protected |
| computeUncertainty(const CCVector2 &pixel, const float depth, Vector3Tpl< ScalarType > &sigma) const | ccCameraSensor | |
| computeUncertainty(CCCoreLib::ReferenceCloud *points, std::vector< Vector3Tpl< ScalarType > > &accuracy) | ccCameraSensor | |
| computeUpperLeftPoint() const | ccCameraSensor | protected |
| Container typedef | ccHObject | |
| ConvertFocalMMToPix(float focal_mm, float ccdPixelSize_mm) | ccCameraSensor | static |
| ConvertFocalPixToMM(float focal_pix, float ccdPixelSize_mm) | ccCameraSensor | static |
| CorruptError() | ccSerializableObject | inlinestatic |
| DEPENDENCY_FLAGS enum name | ccHObject | |
| DeserializationFlags enum name | ccSerializableObject | |
| detachAllChildren() | ccHObject | |
| detachChild(ccHObject *child) | ccHObject | |
| DF_POINT_COORDS_64_BITS enum value | ccSerializableObject | |
| DF_SCALAR_VAL_32_BITS enum value | ccSerializableObject | |
| DistortionModel enum name | ccCameraSensor | |
| DP_DELETE_OTHER enum value | ccHObject | |
| DP_NONE enum value | ccHObject | |
| DP_NOTIFY_OTHER_ON_DELETE enum value | ccHObject | |
| DP_NOTIFY_OTHER_ON_UPDATE enum value | ccHObject | |
| DP_PARENT_OF_OTHER enum value | ccHObject | |
| draw(CC_DRAW_CONTEXT &context) override | ccHObject | virtual |
| drawBB(CC_DRAW_CONTEXT &context, const ccColor::Rgb &col) | ccHObject | virtual |
| drawFrustum(bool state) | ccCameraSensor | inline |
| drawFrustumPlanes(bool state) | ccCameraSensor | inline |
| drawMeOnly(CC_DRAW_CONTEXT &context) override | ccCameraSensor | protectedvirtual |
| drawNameIn3D(CC_DRAW_CONTEXT &context) | ccHObject | protectedvirtual |
| enableGLTransformation(bool state) | ccDrawableObject | virtual |
| enableTempColor(bool state) | ccDrawableObject | inlinevirtual |
| EXTENDED_RADIAL_DISTORTION enum value | ccCameraSensor | |
| filterChildren(Container &filteredChildren, bool recursive=false, CC_CLASS_ENUM filter=CC_TYPES::OBJECT, bool strict=false, ccGenericGLDisplay *inDisplay=nullptr) const | ccHObject | |
| find(unsigned uniqueID) const | ccHObject | |
| fromFile(QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) override | ccHObject | virtual |
| fromFile_MeOnly(QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) override | ccCameraSensor | protectedvirtual |
| fromFileNoChildren(QFile &in, short dataVersion, int flags, LoadedIDMap &oldToNewIDMap) | ccHObject | |
| fromGlobalCoordToImageCoord(const CCVector3 &globalCoord, CCVector2 &imageCoord, bool withLensError=true) const | ccCameraSensor | |
| fromGlobalCoordToLocalCoord(const CCVector3 &globalCoord, CCVector3 &localCoord) const | ccCameraSensor | |
| fromImageCoordToGlobalCoord(const CCVector2 &imageCoord, CCVector3 &globalCoord, PointCoordinateType z0, bool withLensCorrection=true) const | ccCameraSensor | |
| fromImageCoordToLocalCoord(const CCVector2 &imageCoord, CCVector3 &localCoord, PointCoordinateType depth, bool withLensCorrection=true) const | ccCameraSensor | |
| fromLocalCoordToGlobalCoord(const CCVector3 &localCoord, CCVector3 &globalCoord) const | ccCameraSensor | |
| fromLocalCoordToImageCoord(const CCVector3 &localCoord, CCVector2 &imageCoord, bool withLensError=true) const | ccCameraSensor | |
| fromRealImCoordToIdealImCoord(const CCVector2 &real, CCVector2 &ideal) const | ccCameraSensor | |
| frustumIsDrawn() const | ccCameraSensor | inline |
| frustumPlanesAreDrawn() const | ccCameraSensor | inline |
| getAbsoluteGLTransformation(ccGLMatrix &trans) const | ccHObject | |
| getAbsoluteTransformation(ccIndexedTransformation &trans, double index) const | ccSensor | |
| getActiveAbsoluteCenter(CCVector3 &vec) const | ccSensor | |
| getActiveAbsoluteRotation(ccGLMatrix &rotation) const | ccSensor | |
| getActiveAbsoluteTransformation(ccIndexedTransformation &trans) const | ccSensor | |
| getActiveIndex() const | ccSensor | inline |
| getBB_recursive(bool withGLFeatures=false, bool onlyEnabledChildren=true) | ccHObject | virtual |
| getChild(unsigned childPos) const | ccHObject | inline |
| getChildCountRecursive() const | ccHObject | |
| getChildIndex(const ccHObject *aChild) const | ccHObject | |
| getChildrenNumber() const | ccHObject | inline |
| getClassID() const override | ccCameraSensor | inlinevirtual |
| GetCurrentDBVersion() | ccObject | static |
| getDependencyFlagsWith(const ccHObject *otherObject) const | ccHObject | |
| getDisplay() const | ccDrawableObject | inlinevirtual |
| getDisplayBB_recursive(bool relative, const ccGenericGLDisplay *display=nullptr) | ccHObject | virtual |
| getDistortionParameters() const | ccCameraSensor | inline |
| getDrawingParameters(glDrawParams ¶ms) const | ccDrawableObject | virtual |
| getFirstChild() const | ccHObject | inline |
| getFlagState(CC_OBJECT_FLAG flag) const | ccObject | inlineprotectedvirtual |
| getGlobalBB_recursive(bool withGLFeatures=false, bool onlyEnabledChildren=true) | ccHObject | virtual |
| getGLTransformation() const | ccDrawableObject | inlinevirtual |
| getGLTransformationHistory() const | ccHObject | inlinevirtual |
| getGraphicScale() const | ccSensor | inline |
| getHorizFocal_pix() const | ccCameraSensor | inline |
| getIcon() const | ccHObject | virtual |
| getIndex() const | ccHObject | |
| getIndexBounds(double &minIndex, double &maxIndex) const | ccSensor | |
| getIntrinsicParameters() const | ccCameraSensor | inline |
| getLastChild() const | ccHObject | inline |
| GetLastUniqueID() | ccObject | static |
| getMetaData(const QString &key) const | ccObject | |
| getName() const | ccObject | inlinevirtual |
| GetNextUniqueID() | ccObject | static |
| getOwnBB(bool withGLFeatures=false) override | ccCameraSensor | virtual |
| getOwnFitBB(ccGLMatrix &trans) override | ccCameraSensor | virtual |
| getOwnGlobalBB(bool withGLFeatures=false) | ccHObject | virtual |
| getOwnGlobalBB(CCVector3d &minCorner, CCVector3d &maxCorner) | ccHObject | virtual |
| getParent() const | ccHObject | inline |
| getPositions() | ccSensor | inline |
| getPositions() const | ccSensor | inline |
| getProjectionMatrix(ccGLMatrix &matrix) | ccCameraSensor | |
| getRigidTransformation() | ccSensor | inlinevirtual |
| getRigidTransformation() const | ccSensor | inlinevirtual |
| getSelectionBehavior() const | ccHObject | inlinevirtual |
| getTempColor() const | ccDrawableObject | inlinevirtual |
| getType() const | ccSensor | inlinevirtual |
| getUniqueID() const | ccObject | inlinevirtual |
| getUniqueIDForDisplay() const | ccHObject | inlinevirtual |
| GetUniqueIDGenerator() | ccObject | static |
| getVertFocal_pix() const | ccCameraSensor | inline |
| getVerticalFov_rad() const | ccCameraSensor | inline |
| GlobalBoundingBox typedef | ccHObject | |
| hasColors() const | ccDrawableObject | inlinevirtual |
| hasDisplayedScalarField() const | ccDrawableObject | inlinevirtual |
| hasMetaData(const QString &key) const | ccObject | |
| hasNormals() const | ccDrawableObject | inlinevirtual |
| hasScalarFields() const | ccDrawableObject | inlinevirtual |
| isA(CC_CLASS_ENUM type) const (defined in ccObject) | ccObject | inline |
| isAncestorOf(const ccHObject *anObject) const | ccHObject | |
| isBranchEnabled() const | ccHObject | virtual |
| isColorOverridden() const | ccDrawableObject | inlinevirtual |
| isCustom() const (defined in ccObject) | ccObject | inline |
| isDisplayed() const | ccHObject | virtual |
| isDisplayedIn(const ccGenericGLDisplay *display) const | ccHObject | virtual |
| isEnabled() const | ccObject | inlinevirtual |
| isGlobalCoordInFrustum(const CCVector3 &globalCoord) const | ccCameraSensor | |
| isGLTransEnabled() const | ccDrawableObject | inlinevirtual |
| isGroup() const | ccHObject | inline |
| isHierarchy() const (defined in ccObject) | ccObject | inline |
| isKindOf(CC_CLASS_ENUM type) const (defined in ccObject) | ccObject | inline |
| isLeaf() const (defined in ccObject) | ccObject | inline |
| isLocked() const | ccObject | inlinevirtual |
| isSelected() const | ccDrawableObject | inlinevirtual |
| isSerializable() const override | ccCameraSensor | inlinevirtual |
| isShareable() const | ccHObject | inlinevirtual |
| isVisibilityLocked() const | ccDrawableObject | inlinevirtual |
| isVisible() const | ccDrawableObject | inlinevirtual |
| LoadedIDMap typedef | ccSerializableObject | |
| lockVisibility(bool state) | ccDrawableObject | inlinevirtual |
| m_activeIndex | ccSensor | protected |
| m_children | ccHObject | protected |
| m_clipPlanes | ccDrawableObject | protected |
| m_color | ccSensor | protected |
| m_colorIsOverridden | ccDrawableObject | protected |
| m_colorsDisplayed | ccDrawableObject | protected |
| m_currentDisplay | ccDrawableObject | protected |
| m_dependencies | ccHObject | protected |
| m_displayStateStack | ccDrawableObject | protected |
| m_distortionParams | ccCameraSensor | protected |
| m_flags | ccObject | protected |
| m_frustumInfos | ccCameraSensor | protected |
| m_glTrans | ccDrawableObject | protected |
| m_glTransEnabled | ccDrawableObject | protected |
| m_glTransHistory | ccHObject | protected |
| m_intrinsicParams | ccCameraSensor | protected |
| m_isDeleting | ccHObject | protected |
| m_lockedVisibility | ccDrawableObject | protected |
| m_metaData | ccObject | protected |
| m_name | ccObject | protected |
| m_nameIn3DPos | ccDrawableObject | protected |
| m_nameIn3DPosIsValid | ccDrawableObject | protected |
| m_normalsDisplayed | ccDrawableObject | protected |
| m_parent | ccHObject | protected |
| m_posBuffer | ccSensor | protected |
| m_projectionMatrix | ccCameraSensor | protected |
| m_projectionMatrixIsValid | ccCameraSensor | protected |
| m_rigidTransformation | ccSensor | protected |
| m_scale | ccSensor | protected |
| m_selected | ccDrawableObject | protected |
| m_selectionBehavior | ccHObject | protected |
| m_sfDisplayed | ccDrawableObject | protected |
| m_showNameIn3D | ccDrawableObject | protected |
| m_tempColor | ccDrawableObject | protected |
| m_visible | ccDrawableObject | protected |
| MemoryError() | ccSerializableObject | inlinestatic |
| metaData() const | ccObject | inline |
| nameShownIn3D() const | ccDrawableObject | inlinevirtual |
| New(CC_CLASS_ENUM objectType, const char *name=nullptr) | ccHObject | static |
| New(const QString &pluginId, const QString &classId, const char *name=nullptr) | ccHObject | static |
| newDisplay (defined in ccHObject) | ccHObject | |
| NO_DISTORTION_MODEL enum value | ccCameraSensor | |
| normalsShown() const | ccDrawableObject | inlinevirtual |
| notifyGeometryUpdate() | ccHObject | virtual |
| onDeletionOf(const ccHObject *obj) | ccHObject | protectedvirtual |
| onUpdateOf(ccHObject *obj) | ccHObject | inlineprotectedvirtual |
| orthoRectifyAsCloud(const ccImage *image, CCCoreLib::GenericIndexedCloud *keypoints3D, std::vector< KeyPoint > &keypointsImage) const | ccCameraSensor | |
| orthoRectifyAsImage(const ccImage *image, CCCoreLib::GenericIndexedCloud *keypoints3D, std::vector< KeyPoint > &keypointsImage, double &pixelSize, double *minCorner=nullptr, double *maxCorner=nullptr, double *realCorners=nullptr) const | ccCameraSensor | |
| orthoRectifyAsImageDirect(const ccImage *image, PointCoordinateType altitude, double &pixelSize, bool undistortImages=true, double *minCorner=nullptr, double *maxCorner=nullptr, double *realCorners=nullptr) const | ccCameraSensor | |
| OrthoRectifyAsImages(std::vector< ccImage * > images, double a[], double b[], double c[], unsigned maxSize, QDir *outputDir=nullptr, std::vector< ccImage * > *orthoRectifiedImages=nullptr, std::vector< std::pair< double, double > > *relativePos=nullptr) | ccCameraSensor | static |
| popDisplayState(bool apply=true) override | ccHObject | virtual |
| prepareDisplayForRefresh() | ccDrawableObject | virtual |
| pushDisplayState() override | ccHObject | virtual |
| ReadClassIDFromFile(QFile &in, short dataVersion) | ccObject | static |
| ReadError() | ccSerializableObject | inlinestatic |
| redrawDisplay() | ccDrawableObject | virtual |
| refreshDisplay(bool only2D=false) | ccDrawableObject | virtual |
| removeAllChildren() | ccHObject | |
| removeAllClipPlanes() | ccDrawableObject | inlinevirtual |
| removeChild(ccHObject *child) (defined in ccHObject) | ccHObject | |
| removeChild(int pos) | ccHObject | |
| removeDependencyFlag(ccHObject *otherObject, DEPENDENCY_FLAGS flag) | ccHObject | |
| removeDependencyWith(ccHObject *otherObject) | ccHObject | |
| removeFromDisplay(const ccGenericGLDisplay *win) | ccDrawableObject | virtual |
| removeMetaData(const QString &key) | ccObject | |
| resetGLTransformation() | ccDrawableObject | virtual |
| resetGLTransformationHistory() | ccHObject | inlinevirtual |
| rotateGL(const ccGLMatrix &rotMat) | ccDrawableObject | virtual |
| SELECTION_AA_BBOX enum value (defined in ccHObject) | ccHObject | |
| SELECTION_FIT_BBOX enum value (defined in ccHObject) | ccHObject | |
| SELECTION_IGNORED enum value (defined in ccHObject) | ccHObject | |
| SelectionBehavior enum name | ccHObject | |
| setActiveIndex(double index) | ccSensor | inline |
| setDisplay(ccGenericGLDisplay *win) | ccDrawableObject | virtual |
| setDistortionParameters(LensDistortionParameters::Shared params) | ccCameraSensor | inline |
| setEnabled(bool state) | ccObject | inlinevirtual |
| setFlagState(CC_OBJECT_FLAG flag, bool state) | ccObject | protectedvirtual |
| setGLTransformation(const ccGLMatrix &trans) | ccDrawableObject | virtual |
| setGLTransformationHistory(const ccGLMatrix &mat) | ccHObject | inlinevirtual |
| setGraphicScale(PointCoordinateType scale) | ccSensor | inline |
| setIntrinsicParameters(const IntrinsicParameters ¶ms) | ccCameraSensor | |
| setLocked(bool state) | ccObject | inlinevirtual |
| setMetaData(const QString &key, const QVariant &data) | ccObject | |
| setMetaData(const QVariantMap &dataset, bool overwrite=false) | ccObject | |
| setName(const QString &name) | ccObject | inlinevirtual |
| setParent(ccHObject *anObject) | ccHObject | inlineprotectedvirtual |
| setPositions(ccIndexedTransformationBuffer *positions) | ccSensor | inline |
| setRigidTransformation(const ccGLMatrix &mat) | ccSensor | inlinevirtual |
| setSelected(bool state) | ccDrawableObject | inlinevirtual |
| setSelectionBehavior(SelectionBehavior mode) | ccHObject | inlinevirtual |
| setTempColor(const ccColor::Rgba &col, bool autoActivate=true) | ccDrawableObject | virtual |
| setTempColor(const ccColor::Rgb &col, bool autoActivate=true) | ccDrawableObject | virtual |
| setUniqueID(unsigned ID) | ccObject | virtual |
| SetUniqueIDGenerator(ccUniqueIDGenerator::Shared generator) | ccObject | static |
| setVertFocal_pix(float vertFocal_pix) | ccCameraSensor | |
| setVerticalFov_rad(float fov_rad) | ccCameraSensor | |
| setVisible(bool state) | ccDrawableObject | inlinevirtual |
| sfShown() const | ccDrawableObject | inlinevirtual |
| Shared typedef | ccHObject | |
| SharedContainer typedef | ccHObject | |
| showColors(bool state) | ccDrawableObject | inlinevirtual |
| showNameIn3D(bool state) | ccDrawableObject | inlinevirtual |
| showNormals(bool state) | ccDrawableObject | inlinevirtual |
| showSF(bool state) | ccDrawableObject | inlinevirtual |
| SIMPLE_RADIAL_DISTORTION enum value | ccCameraSensor | |
| swapChildren(unsigned firstChildIndex, unsigned secondChildIndex) | ccHObject | |
| toFile(QFile &out) const override | ccHObject | virtual |
| toFile_MeOnly(QFile &out) const override | ccCameraSensor | protectedvirtual |
| toggleActivation() | ccObject | inlinevirtual |
| toggleClipPlanes(CC_DRAW_CONTEXT &context, bool enable) | ccDrawableObject | virtual |
| toggleColors() | ccDrawableObject | inlinevirtual |
| toggleMaterials() | ccDrawableObject | inlinevirtual |
| toggleNormals() | ccDrawableObject | inlinevirtual |
| toggleSF() | ccDrawableObject | inlinevirtual |
| toggleShowName() | ccDrawableObject | inlinevirtual |
| toggleVisibility() | ccDrawableObject | inlinevirtual |
| transferChild(ccHObject *child, ccHObject &newParent) | ccHObject | |
| transferChildren(ccHObject &newParent, bool forceFatherDependent=false) | ccHObject | |
| translateGL(const CCVector3 &trans) | ccDrawableObject | virtual |
| undistort(const QImage &image) const | ccCameraSensor | |
| undistort(ccImage *image, bool inplace=true) const | ccCameraSensor | |
| WriteError() | ccSerializableObject | inlinestatic |
| ~ccCameraSensor() override=default | ccCameraSensor | |
| ~ccDrawableObject()=default (defined in ccDrawableObject) | ccDrawableObject | virtual |
| ~ccHObject() override | ccHObject | |
| ~ccSerializableObject()=default | ccSerializableObject | virtual |
