Can't save .las/.laz files on Mac
kdjacob
Post by kdjacob »
I really hope someone can help me here.
Here's the environment I'm running on a MacBook with Apple M1 silicon running Sequoia 15.3.1.
Attachment 0.jpg (31.51 KiB) Viewed 7628 times
THE PROBLEM: I am unable to save ANY file from CC.
Here is the error message I get in the log window:
[16:29:11] An error occurred while saving '/Users/KenJacobMacbook/QGIS/LiDAR/temp test folder/USGS_LPC_CT_Statewide_C16_830905_nw_lasheight.laz': the third-party library in charge of saving/loading the file has failed to perform the operation
This error occurs if all I do is open a .laz file from the USGS website, do nothing to it, and then try to save it to a new file. And it happens to ALL other point clouds I've processed in CC (wonderfully, by the way -- very happy with what I can do in this program.)
I've attached the state of the save dialog box (I didn't change anything) in case that's helpful.
HELP PLEASE!!!
Sincerely,
Ken
Screenshot 2025-03-08 at 4.28.13 PM.jpg (144.38 KiB) Viewed 7628 times
Screenshot 2025-03-08 at 4.27.52 PM.jpg (125.79 KiB) Viewed 7628 times
Re: Can't save .las/.laz files on Mac
I guess it's related to the github issue?
I'm also concerned that the 2.13 version is getting quite old. We should ask Paul Rascle to create a new binary with the latest 2.14.alpha version...
khzam
Post by khzam »
After upgrading to macos 15.4, all the buttons to open, save and save as are not working. Also cmd+s isn't working. There is no way to save data out of cloudcompare, I tried with these builds "CloudCompare_20250314_161011.dmg" and "CloudCompare_2.13.2__arm64.dmg"
khzam
Post by khzam »
I just built 2.14.alpha from source and the problem I still there. I can't save anything!!
Isn't it different from the initial message? Because at that time the LAS saving dialog was visible...
Anyway, macOS is a different world. So maybe now that you have compiled the project there (good job by the way), you can debug things a little bit?
khzam
Post by khzam »
Sadly the build was a little broken, so I got rid off it. However, from the git issue a tip that worked for mac is to disable "Use native load / save dialog box" from display settigns.
