I am trying to use the Oculus Rift S with cloudcompare and having trouble viewing the pointcloud in the VR environment. I found this thread from 2016 with a similar issue but I'm not receiving the error they mention (http://cloudcompare.org/forum/viewtopic.php?t=1962). Same deal as in the post I linked, the Oculus software runs fine (Oculus App Version 1.38.0.250171), CloudCompare runs fine on its own (version 2.10.2 stereo). But I can't figure out how to initialize viewing the point cloud in 3D on the Oculus headset. All I can do is view the 2D desktop in the 3D Oculus environment (See attached screenshot). I'm running Windows 10 education version 1809 (OS Build 17763.529).
I don't care if the handsets work, I can use the mouse, I would just like to view the pointcloud in 3D on the headset. Does anyone know how to initialize this?
Thanks!
Oculus Rift S
mjgrilliot
Oculus Rift S
- OculusScreenshot1559318319.jpeg (400.04 KiB) Viewed 10320 times
Re: Oculus Rift S
What error do you get (in CloudCompare's Console) when you try to activate the stereo mode? (the reg and blue glasses icon in the bottom left part)
Re: Oculus Rift S
Any update on this? I would like to try my Oculus Shift S on CC too. The first thing I observed is the need for a GPU which does quad render buffering. But I'm in doubt if the Rift S would work or if it only works on the Oculus Rift version.
Thanks Danial for all your work!
Re: Oculus Rift S
I am not aware of any work that has been done to make the recent oculus devices compatible with CloudCompare sadly...
Re: Oculus Rift S
Thanks for the reply Daniel! I'm currently working on my master thesis and I'm trying to use a few different option to of point cloud VR annotation tools. I believe that CC would be a great one for the tests I would like to make. Could you recomend me which scripts to start working on the git repo to try to update de CC stereo to other oculus rigs (like quest 2 or rift S, which are the ones I have) and other graphic cards other than QUAD family?
Re: Oculus Rift S
Well, we don't support Oculus headsets anymore, but we did in the past, so it's technically feasible (you may want to refer to the commit where it was removed: https://github.com/CloudCompare/CloudCo ... 779155d557).
If you manage to make it work again with the most recent SDK, and even with other GPUs, we will gladly welcome the contributions.
