Saturation values
Nursyahira
Saturation values
Post by Nursyahira »
I'm a beginner of this software. I would like to ask how to set the correct saturation value if my study want to focus about showing the movement of landslide. So, which range of values is suitable for the study in order to produce a better results?
Thank you :)
Re: Saturation values
I'm not sure to understand the question: If you are looking for a specific value, then I won't be able to help you as it depends highly on the data, the scale of the objects you're studying, etc.
Otherwise, if it's about the display settings, then I'll strongly suggest you to define your own custom 'absolute' color ramp with fixed saturation values (see http://www.cloudcompare.org/doc/wiki/in ... es_Manager).
