Batch saving all point clouds with CC Object Name as ascii
sage12
Post by sage12 »
is there a way to save all point clouds of any choosen (inclusive subordinate) folder as an ascii file based on the given name of the individual CC Objects automatically in a batch? No Foldername or indexing!
Thanx, Carsten
Re: Batch saving all point clouds with CC Object Name as ascii
One solution is to select all the clouds (you can right click on the top folder and use the 'Select children by type and/or name' tool (with type 'Point cloud'). And then use "File > Save" and choose the "Ascii cloud (*.)" filter to save all of them as separate files (not sure about the filename though, it may be always the same with an index...)
