Moving primitives (translation)
eimixas
Post by eimixas »
What is best way to translate eg. plane?
i tried:
const ccGLMatrix& planteTrans = pPlane->getTransformation();
CCVector3 N(planteTrans.getColumn(2)); //plane normal
N.normalize();
N = N * 0.1;
pPlane->translateGL(N);
m_app->refreshAll();
m_app->updateUI();
m_app->redrawAll();
It moves, after saving project and loading - its position is moved.
But in properties table - bounding box center and dimmensions are not changing, am i doing something wrong?
Re: Moving primitives (translation)
You should call 'applyGLTransformation_recursive' after 'translateGL' so that the temporary GL transformation will be actually 'applied' to the coordinates (and also stored in the particular case of primitives).
Otherwise, the GL transformation is only used for display.
eimixas
Post by eimixas »
Thank you - it works.
