Patchiness after merging two .ply images
Hello, I’m new to cloudcompare. When I’m aligning two .ply images (same object from different angles), the overlapping images resulted in patchiness. I tried to erase the color from one image and interpolated color from the other image. However the area without overlapping resulted in no color. How can I fix the problem? Or I should not have used “color interpolate” to deal with the patchiness issue? Thanks a lot.
Re: Patchiness after merging two .ply images
Can you maybe post an image?
Colors management on overlapping parts of registered meshes may be tricky! And CC is not super strong for mesh / color management anyway.
Have you tried Meshlab to do that? (or even just to fix the issue afterwards?)
