Exporting raster - georeferencing ?
betadk@gmail.com
Post by betadk@gmail.com »
When exporting a raster or image, it seems that the global shift / scale is not restored and the raster is therefore not geo-referenced correctly (point cloud was in UTM). Is one supposed to transform to originals outside of CloudCompare ?
Thanks.
Re: Exporting raster - georeferencing ?
Global shift should be restored when exporting the raster to geotiff (via the 'Rasterize' tool). But indeed, not when exporting to an image.
libak
Post by libak »
Hi Daniel
How do I export a rasta to geotiff while maintaining global shift (scale)?
When I import the geotiff into ACAD, the geotiff is 1mm in length which is not correct - the bounding box in CC is ~39000
Rgds
Which version are you using?
And can you explain how you generated the geotiff exactly? From which cloud?
Ideally, if you could share the original cloud and the parameters you used that would help a lot.
libak
Post by libak »
Hi Daniel
I’m using 2.13.1
This is how I generated the geotiff
> select point cloud
> Hit rasterize button
> set parameters
> update grid
> Rasterize viewport shows my point cloud, ok.
> Export > Raster
> Export RGB colors > OK
> Save as type: geotiff (*.tif)
> Save
> In AutoCAD I enter IMAGEATTACH, and set scale to 1
Now the length of the image in ACAD is 1mm
I can’t share the point cloud, but the size of it is not 1mm :-)
Ah, you duplicated the message... Not sure which thread to follow now...
