Save .obj with XY=00 (not restore original xy)
Tonigau
Post by Tonigau »
I can load geo Lidar pointcloud(from xyz text file), apply shift & scale & cloud is centered in display XY=00. Great
Create mesh & export .obj XY= (restored as per xyz text file import)
Q. How to disable restore original co-ordinates, either on save or clear the meta-data.
I want to keep the shifted co-ordinates in .obj save to import into 3D CAD.
thanks
Re: Save .obj with XY=00 (not restore original xy)
Use the 'Edit > Edit Global Shift' tool. Then reset the global shift vector on the left.
