Can you send me CC 2.6.3 beta (64 bits) with built-in CSF plugin?
Rafalmich94
Post by Rafalmich94 »
Can you send me CC 2.6.3 beta (64 bits) with built-in CSF plugin? 2.6.3 beta is the last version that works on my computer, probably because I have an old graphics card (Intel HD Graphics 3000). In newer versions, if I click CloudCompare.exe, a crash immediately occurs.
Do you think it is a problem with my graphics card that it is too old? Maybe the problem is something else.
I need to use newer versions because they have a CSF plugin built in (I need this plugin for analysis).
CC 2.6.3 beta (64 bits) works perfectly, but there is no built-in CSF plugin. Is a modified version of CC 2.6.3 beta (64 bits) available, with a built-in CSF plugin? Waiting for an answer, help!
Rafal
Re: Can you send me CC 2.6.3 beta (64 bits) with built-in CSF plugin?
Yes it's probably an issue with the graphic card. You can update its driver just in case (but generally it's not sufficient).
And no, the 2.6.3 version doesn't support the qCSF plugin sadly... (the code is not compatible).
