Load file crash
kasper
Load file crash
Post by kasper »
BinFilter bin;
BinFilter::LoadParameters lp;
lp.alwaysDisplayLoadDialog = false;
CC_FILE_ERROR error = bin.loadFile(filename, *obj, lp);
if I Input a file incomplete file or something that cloudcompare cannot read, it won't return an errorcode.
the result I got is the program crash.
How to fix this problem? ( also in StlFilter or PlyFilter )
Re: Load file crash
Is it in your own environment? Do you have a valid qApp?
kasper
Re: Load file crash
Post by kasper »
Yes, coding in Ubuntu 18.04.
"Do you have a valid qApp?" <- sorry, what's that mean?
If i create a txt file and modify the filename extension from txt to stl.
And I load it by the code
it crash.
Re: Load file crash
1) Since everything is built with Qt, you need a properly initialized QApplication (Qt application) instance if you want to see error popus, and working slots/signals, etc.
2) The BinFilter class can only be used to load BIN files (you'll need the AsciiFilter to load ascii/txt files, and STLfilter to load STL files). And if the call crashes, see 1 (at least that's what I suspect).
kasper
Re: Load file crash
Post by kasper »
great! thanks Daniel.
