My colleages and I have developed some codes to work as a plugin in CloudCompare in my organization for in-house use.
Now we want to contribute the codes back to the official master branch for the public to use.
How should I proceed? Need to add test cases scripts before code review?
Pls help.
Thanks,
Pluto
procedure for contributing codes to official master branch
Re: procedure for contributing codes to official master branch
Contributions are always welcome!
Ideally, you should first upload/host your plugin sources on a separate git repository (see for instance https://github.com/hvs-ait/mplane-plugin).
Then you can make a simple pull-request on our master branch, where you add your plugin as a submodule (in 'CloudCompare/plugins/core/Standard' typically). It will let us test it and potentially make some feedback on your plugin repository directly.
Thanks for the link and suggested procedures.
Will discuss with my colleagues and proceed soon with git submodule, git fork and pull request.
Thanks,
Pluto
Thanks,
Pluto
