If you love cutting, but your arm is tired from twitching, Crafters Companion has released a new cheap die cutting machine that you may have been waiting for your entire life.
➤➤➤ Read More: Best Quality Products For Arts, Crafts and Sewing
![Image](https://i.imgur.com/TsYKCRo.jpg)
It's a punching and embossing machine
What is the Gemini machine?
It's a punching and embossing machine like Big Shot or Silhouette Cameo. More precisely, however, it is an intersection between the two. Unlike the Big Shot, the Gemini is electronic and must be plugged in for it to work. However, not the same as Silhouette, you don't need a computer to operate this device. It will work with any occupation or stale folders you already own.
Who is Gemini for?
This best embossing machine gets stuck here. First of all, we should say that Gemini and all other embossing and die-cutting machines are ideal for any paper machine. Cardmakers, card cutters, and even journalists or art collectors can benefit from such a device. In addition to this, Gemini is also straightforward to cut fabric and thin handcrafted metals so that other artisans can use a lot.
➤ ➤ ➤ For more reviews information: CraftsSelection.com
![Image](https://i.imgur.com/X6f5wTh.gif)
![Image](https://i.imgur.com/bmWazgN.jpg)
It works with any minted or extinct folder you already own
If you don't have a stamp or printer, that's right for you, and you have health issues making it difficult for you to do a manual logo. Then we recommend Gemini.
How does the Gemini machine work?
Gemini is pretty easy to use. You can upload your favorite stamp or embossed folder between the corresponding sheets, press a button, and send it off. Because the machine has such a large cutting surface, you can cut various shapes to fit an a4 size insert. We think that this is one of the best Gemini machines because it allows us to cut all the shapes we need for our project simultaneously.
Benefits
-No manual start: With Big Shot, we can never cut as many cubes as our arms can fall off. The most notable feature of this machine is that you only have to press one button. No need to turn by hand.
-Just a tip: WRMK is creating a similar machine called Evolution Advanced. However, on the WRMK version, you need to hold down the button. We think it's good that with Gemini, you only have to press the button once.
-Every size, every brand, the space for Gemini is enormous. You can cut multiple shapes simultaneously and use any die cutting machine brand of any brand with a thin metal shape.
-Invert Button: If you want a deeper indentation or a cleaner cut, you can press Gemini's Invert button and have the sandwich sent back to you through the machine again. You don't have to reload.
➭➭➭ See Page: Selection of Best Product For Crafters and DIYers
![Image](https://i.imgur.com/BrJkexc.gif)
Disadvantages
-The patch warps quickly: We were disappointed that our gasket/base was bent when first used. Of course, we can still use them.
-Pricing: In other die cutting machine reviews, users always want to pay too much for handcrafted items, so this machine only costs $ 200, and it's suitable for you.
