![Image](https://i.postimg.cc/9fQkY7Pf/intens-4.png)
Filter by value is capped
- Contact:
Re: Filter by value is capped
You could try remapping SF values to a smaller range:
Calc icon or Edit > Scalar Fields > Arithmetic:
SF 1: Intensity
operation: divided by
SF 2: [Constant Value]
put in a large number, ie. 1000 or 100000
SF 1: Intensity
How did you generate such big values? As CC store the values on 32 bits, it's generally a very bad idea to use large numbers...
I was searching for an specific post I made and found this unsanswered.
Thank you for hte divide tip, likely that should fix the issue. I can´t recall why intensity values where so crazy. But I keep the tip!. thanks!
