Trouble with creating SF using CLI
JacekJaskolski
Post by JacekJaskolski »
Hi All,
I'm trying to export the Z coordinates to a new scalar field using the command line interface:
CloudCompare.exe -AUTO_SAVE OFF -O C:\CloudCompareIO\test.e57 -COORD_TO_SF Z -C_EXPORT_FMT E57 -SAVE_CLOUDS FILE C:\CloudCompareIO\test+Z.e57
The script runs without any errors and the console acknowledges the operation with a [COORD TO SF] entry, but the resulting cloud doesn't have the new scalar field.
Interrestingly enough, if I use the command on an input cloud which doesn't have the "Intensity" SF then the Z coordinates do get written to a SF in the output cloud, but... CC forces it to be renamed to "Intensity" (Console: [E57] No 'intensity' scalar field found, we'll use the current displayed one instead (Coord.Z))
I have no clue what's going on. Am I doing something wrong or should this be considered a bug?
I'm using CC 2.12 Alpha on Windows.
Re: Trouble with creating SF using CLI
The E57 format doesn't manage scalar fields in a generic way. It only handles intensities. Therefore CC will use the active scalar field as 'intensity' by default. But that's all.
JacekJaskolski
Thanks Daniel, that explains everything!
I'm not bound to E57 for output so I guess I'll switch to PLY or BIN, that should work.
