Performance issues !important
K.Ronald
Post by K.Ronald »
System specs:
i7-8700k 3.7GHz
64GB ram
Quadro P4000
I am using Scene for scan processing and registration. Once I have the SCAN point cloud (not project point cloud), I want to transfer the project to CloudCompare for cleaning purposes (a lot of stray points that cannot be cleaned easily in Scene).
Here comes the issue. I try to open the .lsproj in CC, no issues (only asks if I want it RGB or not). After it opens/loads, it crashes with some information stating I don`t have enough gpu memory, and some other opengl errors. I couldn`t even save the errors because CC crashed and my sceens went black.
I have updated the gpu drivers.
Any help would be greatly appreciated because I`m against time on a project and this tool would help me out.
Thank you,
Ronald
Re: Performance issues !important
Which version of CC are you using? If it's not the latest one (2.12.beta) can you try with this version?
Otherwise, can you share a sample file with me? (admin [at] cloudcompare.org)
K.Ronald
Post by K.Ronald »
daniel wrote: Mon Dec 13, 2021 1:38 pm Which version of CC are you using? If it's not the latest one (2.12.beta) can you try with this version?
Hello Daniel,
I have sent you an email to the given address.
Thank you,
Ronald
I haven't received the email... can you maybe try daniel.girardeau [at] gmail.com?
