Hello everyone, I'm workin in a .laz file, just used poisson recon and have the mesh with scalar field color. I can't see the RGB option at CC Object / Color menu.
I have all the files that was generated with a drone, the .obj opens in 3D Max with perfect maping, but the technician use other programs an can't help me.
Update
I've found that when I try to open a file with less points, te software give me the RGB option, and when I try with the best resolution file, the RGB option freeze:
Can't display RGB
Re: Can't display RGB
If you don't have the RGB option, it means that the information is not present in the file. I guess this information is missing in your high resolution LAS file?
I've talked to the drone guy. He doesn't know why this is happening, the files are the (suppost to be) the same, only with less points...
