Apply a SF to a mesh on the cmd line
James2
Post by James2 »
On the command line...
I have 2 meshes and sample a point cloud for each
I can then calculate the C2C_dist between them and get a scalar field
How do I then apply this scalar field to the original mesh?
James2
Re: Apply a SF to a mesh on the cmd line
Well, if you wish to have the distance values on the mesh in the end, you will have to compute the C2M distances instead (i.e. the distances between the vertices of the second mesh and the first mesh).
Currently, there's no way to call the 'Edit > Scalar fields > Interpolate from entity' tool via the command line.
James2
Post by James2 »
Thanks for the reply Daniel and many thanks for your work on Cloud Compare.
Regards
James2
