I was going to report this as bug but now I'm confused.
I was pretending to make data lighter by removing SF I don´t need, in bulk, via commndline.
To my surprise the outgoing file had exactly same size than input.
I tested manually and by manually deleting, same ressult.
YET, when using DELETE ALL SF there is some size reduction.
So I'm confused wethere this is related to the format, like it may allocate memory for default-ish fields or what. Or may the program be only deleting the reference in the SF array and leaving all the data in there??¿?¿?
