I'm very happy I found CloudCompare because it can display my mesh (obj) together with my constructed buildings (dxf)!
But now I need some help: I want to measure distances in the obj-mesh. I just can't figure out how to do it... I tried to use the pointpicking tool and the compass, too. There are no measurements possible. In a pointcloud (las) it works fine.
I know that the program's name is CLOUDcompare, not MESHcompare :-) But is there a way to get some measurements from the mesh, too?
Thanks! Heidrun
Measure distances in meshes
Re: Measure distances in meshes
It should be possible with the latest 2.11 version. Have you tried it?
Otherwise, with previous versions you have to convert the Mesh to a Cloud (with 'Edit > Mesh > Sample points', using a lot of points ;). Because CloudCompare indeed ;)
thanks for your reply!
It works fine with the new version! Shame on me, I downloaded the 2.10 version in June and did not know there was a new one.
Thank you, Heidrun
Thank you, Heidrun
How to measure the distances between two meshes at certain points ?
Well, you would have to compute the distances between the 2 meshes first, then you can pick a point with SHIFT+left click to read the distance (make sure to use a recent version so as to be able to read the distance anywhere on the triangle).
should we use the global coordinate or te local coordinate ?
And should we use version 2.13 beta or 2.12.4?
I bet global and local coordinates should be the same if you load an STL file?
And I would use 2.13.beta by default.
The 2 d label is = c2m signed distance= the linear distance at that point ? And how we transfer these points yo csv or xcl
When we take the global coordinate each point has xyz coordinates . But in CT it is one number . So we should compare the 2d label to the CT xray numbers ?
