![Image](https://i.imgs.ovh/2023/09/25/PIT6e.png)
As the picture show, I have checked the upsamping method, but i can't modify any parameters about voxel grid dilation.And the console outputs following:
[11:24:34] [Qt WARNING] [] QObject::connect: No such slot MLSDialog::activateMenu(QString)
[11:24:34] [Qt WARNING] [] QObject::connect: (sender name: 'upsampling_method')
[11:24:34] [Qt WARNING] [] QObject::connect: (receiver name: 'MLSDialog')
[11:24:34] [Qt WARNING] [] QObject::connect: No such slot MLSDialog::updateSquaredGaussian(double)
[11:24:34] [Qt WARNING] [] QObject::connect: (sender name: 'search_radius')
I met this problem because i install the flatpak version CloudCompare.Howerer, Versions installed from apt or snap do not have this problem. Here is my install progress through flatpak.
flatpak install flathub org.cloudcompare.CloudCompare
I tried to install the latest version of cloudcompare through flatpak in ubuntu 18.04 and ubuntu 22.04 environments respectively, but the same problem occurred in both of them.
