I think there is a problem with the graphic scale that is generated when the "Render to File" command is executed.
I am obtaining vertical sections of a model and when saving the frontal capture I do not get a scale elevation. In the image obtained, the measurement that appears is exactly 25% larger than the corresponding one (for 4 m a graphic scale of 5 m appears, and for 8 m it appears 10 m), do you know if there is any error?
CloudCompare Kharkiv version 2.13.1
error "Render to File"
Re: error "Render to File"
Did you use a 'zoom' factor maybe? And was the projection mode 'orthographic' or 'projective'?
The system used is orthographic with an adequate zoom to obtain the necessary resolution
Sorry for the late reaction, I was travelling.
I'll have to try to reproduce this issue on my side first...
Thanks for the comunication.
I have reviewed the problem and it seems that it is motivated by the size of the graphic scale, the image shows a value one meter higher than the corresponding one, thus for 4 m it appears 5 m (25% larger).
