SF display param not showing
shafina
Post by shafina »
Hi, I am new to the cloud compare. So, I have align my two point cloud data which is from Agisoft and NerfStudio point cloud. Then, I am using m3c2 to see the differences. Then, after that, the result is not showing, can I know why?
m3c2_sf display.png (20.6 KiB) Viewed 2076 times
Next, when I click on m3c2, in the Normals tab, it cannot be clicked as the image I have attached, why is it?
Re: SF display param not showing
Which version of CloudCompare did you use?
And would you be able to share these 2 clouds with me maybe? (admin@cloudcompare.org)
