PoissonRecon in command line mode or similar?
subo3
Post by subo3 »
is it possible in CloudCompare 2.14 (or earlier) to create meshes via PoissonRecon in the command line mode? It is not featured in https://www.cloudcompare.org/doc/wiki/i ... _line_mode but i guess it is probably not up to date.
What i want to achieve is the following:
Meshing a point cloud and get the density-SF like in GUI-CloudCompare with the PoissonRecon-plugin. Afterwards i want to filter it by SF-Values. In order to automate this process, i need a way to do this in the command line.
Does somebody know if there is a way to do that (with CloudCompare or without)?
Re: PoissonRecon in command line mode or similar?
PoissonRecon is not accessible via the command line because no one did the interfacing work, but also because there's already a command line tool provided by the algorithm's author: https://www.cs.jhu.edu/~misha/Code/PoissonRecon
I don't know if it's also possible to filter the resulting mesh based on the density with his tool though.
subo3
Post by subo3 »
I see, thank you. Do you know if there is a way to calculate the density of a mesh?
Nope...
