I have a question
Primitivism
I have a question
Post by Primitivism »
is there a way to make two planes parallel one to the other? I mean, I have to planes A and B with different orientation each other and with rispect to the global coordinate system, is there a way to make plan A parallel to B. Right now I put A and B parallel to XY plan but I don't need A and B also parallel to XY plan.
I hope I was clear
Re: I have a question
Are you looking for a way to compute the 4x4 matrix that would make them parallel maybe? If yes, you can look at the plane normals and use the 'From > To axes' tab of the Apply transformation tool.
Else, you can clone one of the plane and then translate it anywhere in space with the manual Translate/Roate tool.
