I'm creating a batch that allowed me to open laz file(s) by drag/drop , subsample the cloud, then export it in LAZ.
But when i try to execute the following line, none file is output...
for %%f in (%*) DO "D:\Program Files\CloudCompare\cloudcompare.exe" -SILENT -O -GLOBAL_SHIFT AUTO %%f -C_EXPORT_FMT LAZ -NO_TIMESTAMP -SS SPATIAL 1.00
![Image](https://nsa40.casimages.com/img/2020/08/29/200829114048517603.jpg)
Surprisingly if I chose to export in LAS by modifying
-C_EXPORT_FMT LAZ
-C_EXPORT_FMT LAS
I'm wonderring why can't I export my file in LAZ ? Can't we export in the same format as the input?
Regard,
Arnaud
Update :
Ok after doing some research i've found the problem on https://www.cloudcompare.org/doc/wiki/i ... _line_mode :
"Specifies the default output format for clouds. Format can be one of the following: ASC, BIN, PLY, LAS, E57, VTK, PCD, SOI, PN, PV."
So I see that laz isn't in the list...
Is it possible for a futur version of Cloudcompare to add the LAZ writer ? It will be very usefull !
