i'm trying to compute distance between two clouds and i'm getting strange behavior.
When i try to compute distance between original clouds it's last forever (noticed that the approximate distances are huge), but when i mirror them by Y axis it's immediate.
I've attached four clouds. Couold you take a look at this and give me some clue?
Cloud2Cloud distance issue
- data.zip
- Clouds
- (229.82 KiB) Downloaded 808 times
Re: Cloud2Cloud distance issue
Interesting! That must be a bug, I'll look at this asap.
Thanks for the feedback,
Daniel
Daniel
Okay I found it. This was a tricky one: an ugly round-off issue due to the fact that the cloud was perfectly flat and that the internal tests were not robust to this particular case. So I changed a few things so as to never fall in the same kind of issues in the future.
Here is the corresponding version (2.5.6.beta, 64bits):
(edit: link removed)
Once again, thanks for the feedback!
