Well, that's odd but it's possible if the 'shift' is in the transformation matrix (a case we haven't thought of apparently ;).
Can you share a sample file with me (cloudcompare [at] danielgm.net)?
This way I'll be able to patch the code and issue a new beta version.
PTX import problem
Re: PTX import problem
Ok, that's fixed!
You'll find the corresponding beta version here:
(edit: link removed)
I've improved the PTX loader a little by the way (I've fixed a memory leak, the cancel button is 'smarter' and I now create the sensor objects associated to each scan).
I am not sure why but I can only import ptx files into 2.5.4. They crash on import in 2.5.5 or the provided link for 2.5.6.
Can you share a file with me? (cloudcompare [at] danielgm.net)
The previous poster couldn't because its files were too big... And I can't reproduce the bug on my side with the few PTX files I have on my side.
They are like 1 gb files so I was thinking size may be an issue, but when I open in 2.5.4 save as bin then open in newer version it works fine. I can email you a download link, what address to send it to?
