Export ply option
ccastilloro2
Export ply option
Post by ccastilloro2 »
Dear Daniel,
I am trying to export a filtered density point cloud in ply format in command line. This is the beginning of the command line I´m using:
CloudCompare -C_EXPORT_FMT PLY -PLY_EXPORT_FMT ASCII...
This way, I get: 'Misplaced or unknown -PLY_EXPORT_FMT command'. I guess I´m doing something wrong.
If I remove the -ply_export command, everything works fine but a window pops up asking whether BIN o ASCII format. Is there any way to input the ascii option beforehand not needing succesive clicking in the ply options window?
Thank you in advance, awesome job!
Carlos
Re: Export ply option
This command works on my side. What version of CloudCompare are you using? Is is recent enough?
ccastilloro2
Version 2.6.0. I´ve just downloaded v 2.6.1. and it works!! Thanks!
Daniel, I´ve got another query. Is there any way of saving a merged point cloud in a different folder with a specific name from command line? I´m trying
....-MERGE_CLOUDS c:\filename.ply (I think this should be allowed according to the command line mode guide)
and the command is unknown.
Thanks a lot,
Carlos
Nope you can't specify the output folder/filename yet. This is already in the TODO list however.
ccastilloro2
Thanks for your help and patience anyway!
Regards,
Carlos
