Compilation on Unix
anagno
Compilation on Unix
Post by anagno »
After downloading the most recent trunk and when i tried to compile the program i got:
In file included from /home/anagno/Documents/CloudCompare/trunk/libs/qCC_db/ccCalibratedImage.cpp:25:0:
/home/anagno/Documents/CloudCompare/trunk/libs/qCC_db/ccCalibratedImage.h:158:45: error: ‘>>’ should be ‘> >’ within a nested template argument list
make[2]: *** [libs/qCC_db/CMakeFiles/QCC_DB_DLL.dir/ccCalibratedImage.cpp.o] Error 1
make[1]: *** [libs/qCC_db/CMakeFiles/QCC_DB_DLL.dir/all] Error 2
make: *** [all] Error 2
and
/home/anagno/Documents/CloudCompare/trunk/libs/qCC_db/ccCalibratedImage.cpp:513:47: error: ‘>>’ should be ‘> >’ within a nested template argument list
It is a simple as the compiler mentions. The only changes that should be done is:
std::vector<std::pair<double,double>>*
to
std::vector<std::pair<double,double> >*
Re: Compilation on Unix
Thanks for the feedback!
I have fixed this.
