Saving primitives
cdordoni
Saving primitives
Post by cdordoni »
I have used RANSAC shape detection to generate some primitives.
Is there a way to save ALL the primitives without having to select each one individually in the DB Tree?
Is DXF the only format for saving primitives?
Re: Saving primitives
Not sure if this is already in the 2.6.1 but at least it's in the 2.6.2 (beta) version: you right click on the parent group (in the DB tree) and choose 'Select children by type and/or name' (then simply select 'Primitive'). This will let you save them all at once ... but, you can't save them as true primitives (even as DXF, because DXF is not a real 3D format). You can only save them as triangular mesh files for now.
It would be good to have a real CAD output format (such as STEP or IGES) ... but someone has to do it (or to finance it ;).
cdordoni
Post by cdordoni »
Thanks Daniel.
I'll try it in 2.6.2
I can save the mesh of the primitive in a DXF, I was looking for the other formats like STL or OBJ?
From this list OBJ is the most efficient (PLY is even better if it suits your needs). Then STL and in the last resort DXF ;)
