Scale bar in CC 2.6.1
shunyo
Post by shunyo »
I upgraded to CC 2.6.1 and have not been able to find the scale bar. Is there something I am missing?
Re: Scale bar in CC 2.6.1
The scale bar (if you are speaking of the one giving an hint on the dimension of the scene) is only visible in orthographic mode.
But it may be a display issue. In this case:
- you can try to update your graphic card driver
- and you can try with the latest beta version (2.6.2) - it doesn't use the same version of Qt
shunyo
Post by shunyo »
Thanks for replying. I have tried with 2.6.2 as well. I am still not able to see the scale bar. Is there are toggle switch for the orthographic mode?
shunyo
Post by shunyo »
Oh I have just selected the orthographic projection and it came on. Thank you for the help.
