workflow gripes
torg
workflow gripes
Post by torg »
"translate/rotate tool "
works on object that is selected in DB Tree. Even those that are unchecked/not visible. This for me is never desirable. Operation should only be performed on visible objects.
"aligns two clouds by picking"
I've zoomed the camera/view to exactly where I want it. I selected the two clouds in the DB tree hit the icon and I get zoomed all the way out to cloud extents.
Re: workflow gripes
I understand. But it was intended for very big clouds/meshes (this way you can translate rotate either a small part or a subsampled version while still moving the real entity the same time without struggling too much with a low frame rate).
In this case this is because the tool is in fact creating its own view and sending the selected entities into it afterwards. I'll see if we can copy the camera pose from the origin window (assuming there's only one!).
