save clouds + sensor info.[meta][ascii] (pov)
mengshi
Post by mengshi »
Dear all,
I want save many points (x,y,z) into the format (.pov). Because i want use POVRAY. But when I tried to save, I got :
An error occurred while saving '/data/model' nothing to save
why?
could you help me ?
Thanks a lot~
Re: save clouds + sensor info.[meta][ascii] (pov)
Warning, the pov format of CC has nothing to do with povray (it's an old custom format).
And anyway to be able to generate it I believe you'll need a sensor object defined for each of your clouds.
