how to export .e57 file extenstion from cc to cad
ahmed
Post by ahmed »
how to export .e57 file extenstion from cc to auotocad
or how to know xyz coordinates for any point in cloudcompare
Re: how to export .e57 file extenstion from cc to cad
To export E57 from CC is easy (just select a point cloud and then call 'File > Save' and select the E57 format).
In Autocad I don't know :D
And to now the coordinates of any point in CC, you can use the 'Point picking' tool, or simply click on the point while holding the SHIFT key.
ahmed
Post by ahmed »
thanks
ahmed
Post by ahmed »
.e57 file contain(point cloud + images).
how can extract the images from the file
Aarie
Post by Aarie »
you will have to convert the pointcloud to the rcs or rcp format before you can attach it to an autocad file.
See here: https://knowledge.autodesk.com/support/ ... E-htm.html
Cheers!
