Export SF
tore
Export SF
Post by tore »
Dear Daniel and CC Users,
I would like to export, using a batch file , only the active SF on txt file (or equivalent file), but observing the Command Line Wiki page it seems that this functionality is not implemented yet. Is it right?
There is -FILTER_SF but if I understood well using this command I obtain a new cloud filtered in the range minVal and maxVal
Could you suggest how to do it?.
Thank you for your help.
Regards
Salvatore
Re: Export SF
Actually there's not such option. If you have some programming skill, it shouldn't be too hard to add it to CC though.
Otherwise we can add it to the TODO list, but it's very hard to know when it will be implemented (probably not very fast).
