M3C2
gianm
M3C2
Post by gianm »
Hi, i don't understand what happens if i use the cloud original normals by checking the use cloud #1 normal checkbox.
Normal calculations are avoided by using the original normals or are calculated at the fix scale D. What do you mean in the manual?
Thank you!
Re: M3C2
They are not computed in this case. The existing normals are used to define the search cylinder.
